niceee mx5.
hows your's goin hamish?
the funds are failing me at the moment :D
will have to sell the rolla to do it, but I'm gonna spend some time slidin it first
need to learn to properly drift an underpowered car
with 300rwkw you don't learn to drift properly, you just learn how to wrangle a wild horse
Hard work is the point lol
the rolla is nearly finished so I'm in need of a new project
an the mx5 will be somehin I can daily with no EPA worries apart from exhaust
I can just throw in the stock suspension and zorst and clear any EPA and have a baller daily
That's why I was so confused :D
Hmmm... I need bigger brakes. Not only do these brakes fail to stop but they'll also look fail when I get my SSRs...
I would put my TT Supra calipers on but people tell me it's not worth all that extra weight.
Edited by jezza boii
haha... yeh since i repainted them they look awesome.... and the braking is wayyy up there, especially coming from the 32
if you get a little more power you only weighing it down what 20kgs? max for the whole setup extra.... worth it for better braking that doesnt cost major bucks
woot. just bought a brand new unpainted OEM VW golf MK4 R32 kit.
now the question is, should I get the optional MK5 GTI style front bumper or should I get the regular MK4 R32 front bumper?
MK4 R32 sides and rear:
MK4 R32 front:
real MK5 R32:
same style but for an MK4:
probably should just stick to MK4, cos putting a MK5 front is a lil wanky like R34 fronts on R32's. Mind you there's not that many guys no one who've done it.
I've just posted a thread on MR2 forums asking their opinion.
I could probably get late model turbo brakes for fairly cheap. It just sucks not having ABS. Push down too hard and it just locks up.
I guess with bigger brakes I won't have this problem.
Hmm.. What cheap mods can I do in the mean time? :D Just little shit. Like I just bought NeoGauge dash LEDs for $17.
Finally an excuse to rip my dash out again :P
stop wasting money you don't have on pissy little gimmicks.
$17 isn't exactly substantial.. In fact my workmate payed for it using his Paypal and hasn't even asked me for the money yet :D
I just want to do work on the car but there's nothing to do...
i prefer the mk4 looks cleaner and will suit the look your going for
bigger brakes will just lock you up harder. learn to let go of the pedal when you feel it locking up and then reapply pressure... that's what ABS does anyways, just stops you from stomping on the pedal like a full retard.
Won't the extra braking force increase the problem?
My mate said otherwise. Can't remember what his reasoning was though.
Wouldn't it slow down quicker without having to really push down on the brakes?
Confusing shit lol.
Bigger calipers dont help you stop quicker if you are running shit discs (small). Will just have a quicker lock up effect like funky said.
You need to have bigger calipers and discs for it to brake better.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
