Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :P
$600 in the red FTL
shhh. he's building a track/street car. :D
y'all nga's just lack foresight.
:D
in other news, got caught in that massive downpour before... absolutley soaked :)
least i got the rest of the day off
And you need all this why? Lol
dunno bored i guess
Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :D
$600 in the red FTL
proper shrouded thermo fans > engine fan
shhh. he's building a track/street car. :(
if they are, thats good
was hoping they were std globe and not some uber spec light assembly in one piece
will check it out when i care and can be bothered
dont drive my car to work so not urgent urgent
white ones or yellow ones? or regardless of colour?
All foglights are illegal regardless of colour, pretty lame. Unless they turn on with the headlights then they are legal, but if there is a separate switch then they are classified as foglights
the 32 and the evo both had the foggies in the headlights (both use a switch for them, 32 was the sedan h4 n1 style light)
how does that work then when they came from factory like that but dont turn on when you headlights go on?
I have a button on top of the dash. Near the rear window demister for the foglights
the foglight button would turn on the foggies and the parkers, but i think law means that when you switch to headlights the foglights will then turn on. Some crappy outdated law. I wonder if there is a law for the white LED strips under all the headlights
some confusion between fog and driving lights here
Using fog lights
Front fog lights are designed to better illuminate the road in fog, snowfall, rainstorms or dust clouds. They can be recognised by the narrow pattern of light emitted.
Road Rule 217 states that drivers must not use front or rear fog lights unless driving in fog or other hazardous weather conditions that cause reduced visibility.
Fog lights cannot be accidentally switched on. They must be switched on separate from the main and dipped beam head lights.
Using driving lights
Driving lights are designed to illuminate the road over a long distance. They are the same as the high beam (main beam) head light and emit the same lighting pattern.
Road Rule 218 states that drivers must not use the high-beam headlights when driving:
* less than 200 metres behind a vehicle travelling in the same direction
* less than 200 metres from an oncoming vehicle.
Driving lights cannot be accidentally switched on. They can only be switched on and off with the high beam head lights.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
