Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :P
$600 in the red FTL
shhh. he's building a track/street car. :D
y'all nga's just lack foresight.
:D
in other news, got caught in that massive downpour before... absolutley soaked :)
least i got the rest of the day off
And you need all this why? Lol
dunno bored i guess
Because he got a radiator that was too big and has to piss off the best cooling - the clutch fan :D
$600 in the red FTL
proper shrouded thermo fans > engine fan
shhh. he's building a track/street car. :(
if they are, thats good
was hoping they were std globe and not some uber spec light assembly in one piece
will check it out when i care and can be bothered
dont drive my car to work so not urgent urgent
white ones or yellow ones? or regardless of colour?
All foglights are illegal regardless of colour, pretty lame. Unless they turn on with the headlights then they are legal, but if there is a separate switch then they are classified as foglights
the 32 and the evo both had the foggies in the headlights (both use a switch for them, 32 was the sedan h4 n1 style light)
how does that work then when they came from factory like that but dont turn on when you headlights go on?
I have a button on top of the dash. Near the rear window demister for the foglights
the foglight button would turn on the foggies and the parkers, but i think law means that when you switch to headlights the foglights will then turn on. Some crappy outdated law. I wonder if there is a law for the white LED strips under all the headlights
some confusion between fog and driving lights here
Using fog lights
Front fog lights are designed to better illuminate the road in fog, snowfall, rainstorms or dust clouds. They can be recognised by the narrow pattern of light emitted.
Road Rule 217 states that drivers must not use front or rear fog lights unless driving in fog or other hazardous weather conditions that cause reduced visibility.
Fog lights cannot be accidentally switched on. They must be switched on separate from the main and dipped beam head lights.
Using driving lights
Driving lights are designed to illuminate the road over a long distance. They are the same as the high beam (main beam) head light and emit the same lighting pattern.
Road Rule 218 states that drivers must not use the high-beam headlights when driving:
* less than 200 metres behind a vehicle travelling in the same direction
* less than 200 metres from an oncoming vehicle.
Driving lights cannot be accidentally switched on. They can only be switched on and off with the high beam head lights.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
