pics or it never happened.
For the millionth time :D
Just waiting on the new tie rod bits to arrive so I can sort out that nasty positive camber on the rear/left wheel.
Then I can put on my coilovers and dump the bitch :)
will look good when its slammed
Yep :) I'll have coilovers and suspension bits and pieces by this Thursday so hopefully I get it slammed for the weekend :D
And then one day I'll put the bodykit on... or sell it lol
Then I can put on my coilovers and dump the bitch :D
john deere approved? :)
True. Circuit is incomplete.
legend thanks.
where do you kunce get all this cash from to be just buying coilovers and suspension bits and wheels and shit? mostly directed at jezza
i reckon! doesnt get easier with a full time job either! Im worse off than when I was a casual employee whilst studying! haha
Dead computer, insurance, rego & car ontop. Zzzz
Zergling rush! :)
i had way more spare dosh when I was at uni to mod my car. now it's all spent on women, toys/gadgets, drugs, mortgage, a dog, parking fines and holidays. in uni i worked part time and spent almost all of it on rent and modding the car.
i think its more after you get a fulltime job you realise there's more to life cos you got more money to spend.
Full time work. $650 after tax per week for 3 years straight = over $100k clear (obviously I only saved like 10% of that lol).
I also cut a lot of costs. Like what I'm wearing now = $4 shirt, $14 shoes :) None of that brand name shit.
i feel your fulltime student pain mang. i work like a bitch and save heaps (no smokes or drugs, don't booze much etc)
hopefully i don't realise what other cool shit there is to buy when i hit the workforce. either that or i crack into a decent law firm and clean up :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
