currently have some
255 40 R17 94Y
Yokahama Advan Neova's AD07
2 with camber wear and 2 which have pretty much no tread..
id love to get the same tyres..
problem is im having an absolute bitch of a time finding somewhere with prices / where i can buy them
does anyone know where i can find..
*sorry i wheel newb :)*
traction tyres is yokohama distributor. else try one of the sau sponsors.
still waiting on custom wheel outers to be machined up and the centres powdercoated.
in the meantime i got our painter to track down either Nissan Midnight Purple II or BMW Interlagos Blue samples for paint. Then it's a matter of rolling/pumping the guards out for extra width which should cover the 11" wide wheels in the back :)
Still divided on paint. MPII would be sweet, but the base colour of the car is blue... which may or may not work too well with a blue-purple-black flippy colour.
go the MPII, it looks awesome in the sunlight and just as good if not better in artificial light. when i just went outside before it was a really nice dark looking purple and then when i walked closer to it it changed to a blue/green colour, it looked awesome :P
yeah but MP2 is a nissan colour. this is a golf... at least Interlagos Blue has some euro history behind it.
Although then the cream leather interior and MP2 should look sweet together. If I go the Interlagos Blue I'll have to change the interior to tan instead of cream. Wheels will have to be a different colour instead of blue barrels and black spokes too if I go MP2. Maybe bronze barrels and black spokes?
Also, there's no green in MP2. MP3 has some fucked up hectic bro chameleon goin on, but MP2 is just straight blue -> purple -> black transition. Black basecoat, purple midcoat, blue pearl in clear.
Also, there's no green in MP2. MP3 has some f**ked up hectic bro chameleon goin on, but MP2 is just straight blue -> purple -> black transition. Black basecoat, purple midcoat, blue pearl in clear.
ok, i must be a bit colour blind then lol because in some angles and light it looks like it has a green tinge in the blue.
have you got a pic of the interlagos blue?
just a quick question if i got some new z tune side skirts and rear pods would it be hard to spray and match up this colour properly?
shan roughly how much is it costing for ur wheels to get done man?
base was $1500 for centres and inner barrels and $1000 for outer barrels. Plus new bolts, labour, powdercoating etc.
full homo cos it's 5x100 fitment that nothing else seems to use other than shitty old toyota celicas, and even then they're like +40 offset which is useless on an euro.
wow, that blue is very nice.
yeah it's a blue base with purple pearl and then a clear with some light blue pearl in it... or someshit like that.
same car, two angles.
Subies are 5x100 too.
also with +40 fitment.
as are Prius' which also run 5x100.
The Works I got are for a Subie, but then with custom outers machined up to my specs so that the offset goes from 18x7 +29 to 18x10.5 -15 :)
mp3 is the f**king shit!
jamie, that 180sx you posted, always see it around my way.
and
today after school, walking across the oval to cross mahoneys road to find a juniors ran across the road and got cleaned up by a van at 60km...
you are worse than a fkn woman
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
