sooo.. how powerful would one of these be with a 350Z TT setup
I think APS made the 350Z run 12's.
the silver 180 low as fk and certified gangster?
Yeah that's the 1!
probably a panhard flat twin
I see, thanks!
Ppfftt shan. You will only get a little respect when you actually have a car with hellashit fitment.
If you mod your car to get respect from others you should work on your self esteem :/ sorry but you just sounded really silly saying that
you're the one who implied that we mod our cars for the respect of others retard.
because it's a DB HBR5, not a Fairlady Z as the filename suggests
Yeah, I was just doing a little reading and it saying it is a 2 cylinder sub type "Boxer" engine.
Seems to be more of a motorcycle engine.
Cool!
Thanks again.
yeah, looks awesome
also a black one at the electricity joint up mahoneys road, red p plater, primered patches all over the car, flared guards and some sweet sweet fitting dteks
cracked a stiff while limping to work
lol that's ghetto... lotsa maccas wage rolla boys do it and think it's the shit.
but if you are gonna do it, at least turn it the other way around and bolt it to your bumper.
failing that just get a ghetto spec 180SX bumper lip, turn upside down and fit to R32/33 bumper.
its 'L' shaped. will be bolted.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
