i like buying expensive clothes. that probably makes me a phag. but i still love this shit:
apparently she was at some bar with ruby rose last week.. my matesthat managed to get in saw her but i couldnt get in lol
after his glowing appraisal, i'm expected to buy it off him? lol
still no idea what to do
depends on what you want...
i prefer my boost to spike a little at the start to get things happening, which is why i have the gain set to max. trent has added the timing progressively to keep it safer
and in all seriousness... i dont mind it trailing off near the limiter with 300rwkw on stock internals
sell him your spec "s" kris...
I run one and find it is perfect for my needs.
It spikes to 20psi and then trails off to like 18.5 by 7400 with the gain set to full :laugh:
He could if it was still his...failed to mention that he'd already sold it to me :domokun:
Spec S is perfect for running 14 psi on the GTR :(
pwnd hard. thought you road rego'd track day car was stealth?
twas. All he could get me for was my bleed valve. Which was covered in duct tape and shoved under the intercooler piping. It got slightly moved when the power steering lines were customized. Cop had his massive flashlight and was viewing the turbo from every angle to find it.
His only mission was to find a boost controller and was set on finding one...
4yrs of daily driving in Knox/Rowville, it was only time until an epa showed up
After all of this, will just run an adjustable actuator and prob get one of those legal exhausts from racepace.
Then they can go and get f**ked.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
