i like buying expensive clothes. that probably makes me a phag. but i still love this shit:
apparently she was at some bar with ruby rose last week.. my matesthat managed to get in saw her but i couldnt get in lol
after his glowing appraisal, i'm expected to buy it off him? lol
still no idea what to do
depends on what you want...
i prefer my boost to spike a little at the start to get things happening, which is why i have the gain set to max. trent has added the timing progressively to keep it safer
and in all seriousness... i dont mind it trailing off near the limiter with 300rwkw on stock internals
sell him your spec "s" kris...
I run one and find it is perfect for my needs.
It spikes to 20psi and then trails off to like 18.5 by 7400 with the gain set to full :laugh:
He could if it was still his...failed to mention that he'd already sold it to me :domokun:
Spec S is perfect for running 14 psi on the GTR :(
pwnd hard. thought you road rego'd track day car was stealth?
twas. All he could get me for was my bleed valve. Which was covered in duct tape and shoved under the intercooler piping. It got slightly moved when the power steering lines were customized. Cop had his massive flashlight and was viewing the turbo from every angle to find it.
His only mission was to find a boost controller and was set on finding one...
4yrs of daily driving in Knox/Rowville, it was only time until an epa showed up
After all of this, will just run an adjustable actuator and prob get one of those legal exhausts from racepace.
Then they can go and get f**ked.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
