Yeah still there unfortunately....Another 4-5 months and I should be gone though....Start my sparky pre-app on Monday :yes:
Got offered a contract at Schweppes but knocked it back, pre-app is full time so I'll need to be doin a few night shifts for the next 4 months, then hopefully gone forever!
P.S Still dying.
Awesome man! Where are you doing your pre-app? When your done the pre-app and looking for work, let me know I'll see if work will take another apprentice on, but we just took a new apprentice on so it's not promising.
370 degrees/victec..
One of my mates is pretty sure he can hook me up when I'm done so I should be ok, but I'll keep your offer in mind as well :thanks:
I did mine there. Wasn't too bad, yet that was 8 years ago :down: Might have changed a fair bit since then.
What sort of work does your mate do?
Maybe someone in the wastelands will know this.
Before my diff died i realised that the car was driving much slower, as in getting bull boost by 5000Rpm :s felt a lot slower. so question is, if your diff is still working, (as in car moving) can a f**ked diff have a power loss at the wheels?
I did mine there. Wasn't too bad, yet that was 8 years ago :) Might have changed a fair bit since then.
He's a 3rd year working through 370....he's injured at the moment though so not working
Ahh so you mean you'd work for Victec? (Or whatever they're called now?) lol. I did my apprenticeship with them too, but was kept on the entire time by the same company.
Had to work today too, looks like I'll be doing a 20-odd day stint without a day off :)
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
