sorry mate you are right, from one end of the exhaust i can fit my hand in but when i try to go through the muffler i can almost get my hand in.
ah yeah thought they were like that, not that it really matters they still flow a lot and the main thing is they keep the noise down :laugh:
^ lol
i got a question for people that know about fitment with rims and stuff. first to clarify im not buying these im just interested in this offset because i dont undertsand what it would look like. ive never seen a number that low usually around +13 offset and stuff like that is what ive seen so im just curious.
http://cgi.ebay.com.au/Lenso-PROJECT-D1R-D...rts_Accessories
18mm more inner clearance (between rim and strut)
and extends out another 44mm
fucken power went out last night, froze while i slept :(
pics phag stop keepin me hanging its like trying to stream a p0rno on dialup..
yeah 4.3 is more normal, no one would sell aftermarket 3.4 diff gears, it would be horrible
so yeah with 4.3 you will get quicker acceleration and lower top end speed
and at 100km./h youll rev more, but your traction will be more important
as it will likely induce more wheel spin as the rotation speed is higher for lower gears
so when you come on power it will likely wheelspin even more if you dont have good suspension/tyres/rear setup
If they dont do the work they shouldnt have taken the diff. It was second hand but there was nothing wrong with it. When the guy opened it today he saw straight away that shit wasnt right. Might be a good thing, im over the 2 ways now, want a 1.5 way.
the point is that it is sent to a specialist who know what they are doing... it's what most tuners do as it gets the customer the best product and doesn't hold up the workshop
yeah creatd don't bust apart diffs.
also how do you assemble a diff wrong if you give em a housing and an assembled 2 way? There's only one way you can assemble it, everything either fits or it doesn't.
i'd say it was f**ked when he bought it and kinda worked when it had fresh fluid in it...
not too upsetting considering what you paid for it kris :(
fucken power went out last night, froze while i slept :laugh:
weird... i was warm?
the lenso's are -1 not +1..
hottt
noooooooooo
wow didnt know auto 33 had higher diff gears than manual
so it runs less boost but higher diff gears
fair nuff
never had a boost gauge in my car, but what should the stock one read at in a manual, assuming standard dump/cat and no other mods?
if it's a bog stock ECR33 auto then boost is 5psi switched to 7psi at 4500rpm
if its a bog stock ECR33 manual then boost is 7psi swithced to 9psi at 4500rpm
for 100km/h in ECR33 manual it is 2650rpm
for 100km/h in ECR33 auto it would be around 2850rpm ish ?
hottt
took that into consideration when i worked it out :)
haha i got a shitty phone pic, cars is dirty as though :huh:
although you dont notice it much being yellow
fark you, power only came on at like 4.30 in the morning so shitty night :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
