handling & power > autosalon fagging
It's already fast enough with the GEN3 engine and current power mods. I might raise the boost later down the track but for now I'm very happy.
Handling wise, again it's pretty damn good (in stock form, mind you) but I am doing a few upgrades.
So far I have bought BC Coilovers, Cusco front/rear strut braces and I guess my lighter wheels and decent tyres count as handling mods too (or braking more-so).
Future plans include sway bars and a few other small things.
I'm not "autosalon fagging". The Recaros are for holding me in my seat through fast corners. If I wanted new seats for cosmetic reasons I would get my mate to retrim them for cheap.
I'm taking my car to Haunted Hills later this year so all these mods are for a reason :)
I've never seen an MR2 come with bucket seats from factory. Not even the late models. I don't doubt you though.
Here is a 1998 interior. These seats look a little bit more bucket-like than mine, but it could just be the angle.
The only differences I've seen are leather or suede trim upgrades.
Surely you wouldn't classify them as buckets?
Edited by jezza boii
^^^ those look like celica seats.
the late model MR2 GT-S (post 96... think that's a S3) came with some sweet optional leather buckets that cuddled your nuts better than a puertorican whore.
I <3 the GTR seats plenty of bucket for a daily!, although from the feel of them they wouldn't be very comfortable for a larger gentleman as they are pretty narrow and firm.
You should buy Aarons r34 gtr seats jezza :)
you're also a massive homo, so I guess that kinda splains it.
alex, I bought a boser metal extension for the hood this weekend. $500 delivered from the US :)
next paycheck = respray and panel work. also need to figure out how to pop the boot.... like any good pornstar, teh golf is havin her back door shaved.
thats steep but cheaper than custom, plus its like unique +10 baller points to you sir.
yes... i am gonna leave the line on the teks for a while....
oks i knew a guy sellin a pair ill keep an eye out for ya man
R32 gtr seats are the most hugging. But they still suck because they don't have thigh support so you still slide around. Still want that bride gias low max mmm
yea
r32 gtr seats are sweet
being a big boy, i was always worried my ass wouldnt fit in them
but when i went to take pics of jamies r32, i jumped in and fit, nice and snug
happiest day of my life
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
