according to work usa, the 9's are Odisk @ 96mm, the 9.5's are Adisk @ 83mm. curious enough to search lol
uhhh ALL works wheels come in A, B,C or O centre. You choose the centre based on the brakes you're running and what kind of concave etc you want.
just get whoever's buyin you the wheels or gettin em from to measure the lip for you if all you wanna know is how much dish you'll have. You can't tell that just by using the offset and width.
yes yes i knew that disk affects dish - just didnt know which was which, and i dont really care exactly how many mm of dish i will get. just bored and decided to learn something. now what i dont know is whether o disk will clear gtst brakes.
also it seems i'v broken my right hand shift button on the keyboard
FML, So as a condition of roadworthy I had to get my drivers side window working (previous owner disconnected as it wound itself up) So I took it to the auto-elec today and they rang me during the day to come get it........ FARK final cost= $360.46 wtf? just to fix my window are you serious????? :D
That's my gripe for the day :)
I was a year and a bit...
That's a fair while. I thought I was bad @ 6 months late.
If I got my license at 18 I would be getting my fulls in 4 days :) Unfortunately I've gotta wait til next year.
If I got my license at 18 I would be getting my fulls in 4 days :D Unfortunately I've gotta wait til next year.
LOLnoob....L2getlicensethedayyoucan.
I got my Ls the day I turned 16 and Ps the day I turned 17. I was even late to my PD/H/PE HSC exam because of it :)
At the time I was living out in the sticks. There was no friggin' way I was going to wait a single day longer than I had to to get my license.
At the age of 18 I had no interest in driving. I could walk/skate to school and friend's houses. I didn't even like cars at that stage.
When I started working I realised that I needed to drive. Did 15 hours on my L's and then fluked my P's test.
Once I started looking to buy a car I realised how awesome they were :)
had my L's at 16, P's on the day I turned 17, lost it by the age of 19. Full license at 21.
I'd have had my full by 19 if I hadn't lost it, but cos I lost it I went into the 3 year P-plate system instead of the 1 year P-plate. FFFUUU.
So you on full license now...
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
