Why do you work so much man?
I'd rather get less money and have more free time. If you're not out enjoying life then what's the point?
HAHAHA!!! I enjoy dont you worry.. :P ...and sif i work hard when i am at work...i am more on this forum than actually trying to work...so getting money to sit around and do nothing...i dont mind... :P
I can bypass the proxy server, which means i can get onto what ever site i want but then i'll just get in trouble so not worth it anyways i sometimes just use this method for a picture i really want to see or something not sitting on facebook at work or anything
How do you bypass the proxy server? Other than the obvious option of using proxy sites.
Get off the f**king facebook and do some work :P
But atleast it keeps you "busy" during the day...
Eh... I make my boss MILLIONS. I think I'm entitled to a little bit of entertainment to keep me sane while I maintain a database of over 50,000 clients and add a further 200+ a day :P
i bet you have been on it ten times by now anyway....YOU GET TO WORK YOU LAZY BUM!!! LOL!!! :P
How you do that? easy to do?
Well my workstation computer has XP (like most would) and has restrictions for my user account obviously and the internet browser runs through a proxy setting ie. proxy.internal.xxx.net.au on port 8080 which your company sets up and blocks sites such as facebook so when your accessing facebook with your computer its like "nah dude you cant do this at work category: social networking or what ever"
All I do is just login with remote desktop to our database server and use the browser there.. has no need for proxy settings in it at all and have complete access like you would at home
YOUR A NERD GENIUS!!!!!!!!!!
Hmm.. Seeing as I love black but can't afford a full respray - what about half and half?
I'm thinking black roof, bootlid and spoiler...
Boot/spoiler like this: http://i101.photobucket.com/albums/m79/gre...R2/P1000798.jpg
Roof like this: http://i723.photobucket.com/albums/ww231/grk801/IMG_0010.jpg
My car just got resprayed in red about a year ago :P And I wouldn't mind doing the whole exterior again... Just don't wanna pay for engine out, door jams etc...
Edited by jezza boii
bah sent a letter to EPA requesting a warning due to being on business trip for the past 3 weeks. Just got a letter saying, they wont fine me but still need to clear EPA :D
Guess i'll be trailing the car up to motorkhana this weekend and then deal with the whole epa hassles :dry:
Anyone got a factory r32 airbox, factory r32 catback and factory ecu they willing to sell/lend me?
Thanks
Ouch pat. I got done for a defect. Hopefully no EPA follows :s
no goods. I got driver dynamics track day on 16th October. So have to restore everything to stock, clear the epa and put everything back on in 3 weeks! zzz
lol, I know, jspec sold the one I was looking at!!!! :dry: (I knew the site being down was bad luck!) I sent them an email with my preference and the next time one comes up I think I'll grab it. Then I'll get a tow bar. And pull my loves on the back. lol. WEEEEEEEEEEEEEEEEEEEEE!!!!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
