lol @ those leather seats, you're gonna have fun trying to keep them clean and stain free :thumbsup:
True, he'll probably lay down some skid marks when he snap oversteers in the wet or if Kris cuts him off while "cruising".
stop having boring tuna. chop chop chop chop.
Boring? I love it. Have it every day
bullshit asshole noone likes the tuna here
I do actually...
P.S I was gonna add that to my post to save everyone the hassle of posting the obvious!
sirena is best canned tuna imo
Safeway is actually the best imeo.... The only brand to use 100% olive oil and not an 'olive oil blend'. I don't do the flavored shit
new TE's look shit hot on old clunkers...
KE rolla boys, get on it now instead of trying to jump the bandwagon 3 years later.
once i get the 55 going will look into them, but may be too old to use them
salami and cheese toastie while waiting for pasta to cook. nom
salami and cheese toastie.... a maso basic food group lol
they are awesome :)
I do actually...
do they do chunks? never had safeway
sirena is wayy overpriced
they are awesome :)
yeah they do chunks, think they were on special at $1 a can last week for the small cans... Think greenseas might be on special this week, picked a fair few of em at work..
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
