i just got the rego... pretty clever...
for those that didn't...
this:
is an AIM 9 sidewinder missile
lol
-celsior and +golf and you have what I'm doing >_<
where would 18x9.5+25 sit on a celsior shan?
i was thinking about 5 out on the front and 5 in on the back from wha i have seen
so mebbe 15mm bolt on fr and 20mm bolt on rear
i saw something weird this morning...there was a car accident on the freeway...two cars...one blue and one silver...they both were smashed...but when drove around it, i saw a RED bumper sitting near the scene...lol...could it be a hit and run? or the accident was cuased due to a bumper falling off another car...what you guys think? it really confused me..
3way and the red car was already towed?
hit and run?
bumper fell off another car?
red bumper was in the rear cargo hold of a dc10 and the cargo door blew out (as was the style at the time) leaving the bumper to fall to earth?
red bumper thrown off overpass?
there was no red bumper?
red bumper was infact not in the book depository, but on the grassy knoll?
that gopher from caddyshack did it?
you are colourblind?
it was eps.
hit and run?
it was eps.
what the fark?
nah... place will be bone dry as usual
the targa tasmania boys have a buller event scheduled for the week after so i think we'll be right wink.gif
but how did you see it when it's after yours? >_<
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
