thats what nisskid recomended with stock guards and low.. any chance sedans are different?
not sure if different on sedans but, I had scrubbing issues with 17x8 +30 with 235/45 tyres
Had to drop to 225/45's to reduce scrubbing
You are going another inch wider and +20, that will be an interesting fit.
The r33 GTR rims are 17x9 +30. Have a look through the r32 image thread for those rims on the r32. That will give you an idea if there is room for +20
got an invoice for my bodykit from VW US. Including shipping to oz it's $1500 cheaper than what VW AU wanted for the same thing.
Fucking muppets.
Mohsen, fuck you and your fucking pipedreams. Buy a car. Until then I ain't giving you any advice on nothing.
Fucking muppets.
saturday. if nothing goes wrong
kris is right there....
be smart man...
having said that... pat's a fag... those wheels will fit easy... just need to flare more\
why people are afraid of flaring guards on a ~10k car is beyond me... just man up ffs
you wanted aggressive fitment, Rekin runs pretty mild fitment.
the reason why his scrubbed is:
A: he was running a big tyre
B: his guards werent roll enough/right
C: his suspension was too soft
with 17x9 +20 u will be running a 215/45, hard suspension, then u will go at ur guards, just enough to make them fit (rolling and slight pulling in areas). when i talk about stock guards there i mean rolled guards as it's kind of a given if u want any sort of aggressive fitment. u wont need to flare to get a 17x9 +20 under.
17x9 +16 225/45
might have to do something about my spring rates. or do i hope it'll tuck on launch? she squats atleast an inch
getting aggressive fitment on soft suspension is farkin hard, doable, but hard. if u want the aggressive look, then harder springs are ur best bet. but realistically u wanna be going harder dampers as well.
im gonna see how far i get with what i have because i like the ride atm. but i could also do with less roll in corners. its the SK gb spec bilsteins/whiteline fyi.
im running 18x10 +19 all round, 235 and 245. lipped and slightly pulled. no scrubbing cos of how high it is but next thing on the list is low
the circlip adjustment is just the start of ur woes, the biggest problem is they use the standard hats, by having the top spring seat sitting down so low, ur spacing the suspension up, lifting ur car effectively.
u need to turn this:
into this:
be smart man...
seen the car, doing a final check on saturday.
17x9 +16 225/45
awesome, thanks. now to work my ass off again and save for some decent rims/ suspension :blink:
be smart man...
yeah i dunno, i did it on the rear of the evo and it was fine
and thats a low 20 grand car
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
