why people are afraid of flaring guards on a ~10k car is beyond me... just man up ffs
this.
mallet and dolly that shit, then hit it with paint. hell, just a simple roll will do if you wanna go princess spec and get you some extra clearance.
asking pat for fitment and stance advice is like asking the pope about what type of condom gives the wimmins the most pleasure.
this is true... but how about asking the pope about pleasuring little boys? different story eh!
also, just think how many 32gtst's run 17x9.5+18 drifteks... it's been proven that +20 will fit time and time and time again
:blink:
f**king nisskid owns!
A Word from the Wise Mohsen,
Shan
Nisskid
Abu
Hamish
Blaq
Nick
^^ Listen to them in regards to wheel fitment and you won't go wrong.
will do!
but would it look good? that is the question
wheels look fuckin awesome when they're sitting on the ground NOT on a car. maybe if you had a car to consider them against, then maybe we could be more subjective.
in short. stfu about wheels/bodykit/suspension/air freshner/whatever and just buy a car first. We've heard this broken record of yours for the last year, and honestly it's just fucking irritating now.
wheels look f**kin awesome when they're sitting on the ground NOT on a car. maybe if you had a car to consider them against, then maybe we could be more subjective.
in short. stfu about wheels/bodykit/suspension/air freshner/whatever and just buy a car first. We've heard this broken record of yours for the last year, and honestly it's just f**king irritating now.
:rofl: i thought c210's were cool.. k lol
:rofl:
Fucking nisskid owns!
Shan
Nisskid
Abu
Hamish
Blaq
Nick
and alex :D
haha owned
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
