lol awwwwwwwwwww cute kent
yeah i think this cars alright, uncle did the usual accelerate hard tests n brake hard etc.
previous owner before this one was 80 years old....
lol 80 years old. lol. right.
anyways, my purchase for the day... for the golf:
Front Suspension Refresh Kit - Stage 3 (lol @ americans and their "stage" concept)
TT Short Shift Kit - With Shifter Cable End
Complete air ride system with AutoPilot Digital air management system
ECS Adjustable Sway Bar End Link Set
ECS Ultimate 2.0L Timing Belt Kit
ECS Urethane Rear Coil Spring Isolators
w00t. there goes half of my tax return :happy:
really wanna see pics of this golf
looks like shit atm. gimme 2 months to put all the shit on it.
the guys birthdate is on the previous rego papers.. 1936 :happy:
i'll bet money that it's the shop owner's old man's details. it's a common trick used to transfer rego by shops. there's a tax loophole and vicroads loophole involved, which I'm not gonna discuss on here.
nothing illegal, and perfectly within the dealer's rights, so don't worry and lose any sleep.
Hmm very interesting purchases Shan. Unfotunetly not much stuff to buy from the U.S for 33's because there is f**k all there. Unless you have sites that you can share with me? I wanna spend money :happy:
hahah..+1..cant find what i want...hate when that happens...
ufff exhaust and turbo coming off tomorrow. Then to rewire factory AFM and pray to god they dont find my injectors as that is game over my friend...
anyone have a factory r32 AFM plug? I chopped mine off when connecting the z32 and lost it :happy:
Won't your injectors run shit on a stock ecu, affecting your emissions?
reprogramming the eprom in the ecu with the injectors corrected. If that fails, I will solder the chip directly onto the board, then they cant say shit.
did you just fkn call him cute? and did he just let that slide? what the hell is going on in here?
congrats btw
so i decided a little while ago to bolck off my bov for a leak finding exercise....
long story short, i noticed that my car runs the same whether the bov is blocked or not
many people report that blocking the bov makes the car have aids (with the stalling and what not)
people that complain about stalling etc usually have a very very mildly modified car
people with properly modified cars have a standalone ecu that normally ditches the closed loop 02 sensor
so my theory of the day is that blocking the bov only affects cars with the closed loop switched ON
yes? no?
congrats btw
cute has kinda become part of a bromance dictionary here in the north.. dont know whats going on in the east..
Why did you go Auto?
because im lazy
Any chance you got a CAD drawing of them? Might pass them onto the toolmakers at work to make up a set :)
I got my rings from speedy wheels
http://www.speedywheels.com.au/
Sent them an email telling them the ID and OD required and it cost me like $20 incl postage for all 4
i had some basic drawings of them. but ur better off doing them urself.
mine were done to my coils ID, the urethane bushes i had (superpro) and the bilstein shaft OD. the design is pretty basic.
from here i just drilled holes, counter-sunk the holes, then fit some bolts up through there. and yes the bushes are in the wrong way.
i also created some spacers to space down the bump stop to make sure the bump stop was what was bottoming out, not coil bind. this is done by taking basic measurements and getting the scrag figures for your coil (hyperco and eibach both have these in their catalog i believe)
Very nice.
What was your reason for the hats? Looks to me like you can achieve a lower setup without dropping down the circlip? This would mean more suspension travel without hitting the bump stops?
lol, it's easy man... just get 15mm bolt on spacers, and run smaller tyres.... get generic ones that have hub rings on them and then get some adapter that close the gap between the ring on the spacers and the oversized hole in the professors :wub:
run camber on the front and/or smaller tyres
i have 8" rims on my ksev and i run 195/50/15's
At least you make sense when you explain it :) Thanks man!
Now I just need to chew through my fresh tyres before I can buy smaller ones haha.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
