lol awwwwwwwwwww cute kent
yeah i think this cars alright, uncle did the usual accelerate hard tests n brake hard etc.
previous owner before this one was 80 years old....
lol 80 years old. lol. right.
anyways, my purchase for the day... for the golf:
Front Suspension Refresh Kit - Stage 3 (lol @ americans and their "stage" concept)
TT Short Shift Kit - With Shifter Cable End
Complete air ride system with AutoPilot Digital air management system
ECS Adjustable Sway Bar End Link Set
ECS Ultimate 2.0L Timing Belt Kit
ECS Urethane Rear Coil Spring Isolators
w00t. there goes half of my tax return :happy:
really wanna see pics of this golf
looks like shit atm. gimme 2 months to put all the shit on it.
the guys birthdate is on the previous rego papers.. 1936 :happy:
i'll bet money that it's the shop owner's old man's details. it's a common trick used to transfer rego by shops. there's a tax loophole and vicroads loophole involved, which I'm not gonna discuss on here.
nothing illegal, and perfectly within the dealer's rights, so don't worry and lose any sleep.
Hmm very interesting purchases Shan. Unfotunetly not much stuff to buy from the U.S for 33's because there is f**k all there. Unless you have sites that you can share with me? I wanna spend money :happy:
hahah..+1..cant find what i want...hate when that happens...
ufff exhaust and turbo coming off tomorrow. Then to rewire factory AFM and pray to god they dont find my injectors as that is game over my friend...
anyone have a factory r32 AFM plug? I chopped mine off when connecting the z32 and lost it :happy:
Won't your injectors run shit on a stock ecu, affecting your emissions?
reprogramming the eprom in the ecu with the injectors corrected. If that fails, I will solder the chip directly onto the board, then they cant say shit.
did you just fkn call him cute? and did he just let that slide? what the hell is going on in here?
congrats btw
so i decided a little while ago to bolck off my bov for a leak finding exercise....
long story short, i noticed that my car runs the same whether the bov is blocked or not
many people report that blocking the bov makes the car have aids (with the stalling and what not)
people that complain about stalling etc usually have a very very mildly modified car
people with properly modified cars have a standalone ecu that normally ditches the closed loop 02 sensor
so my theory of the day is that blocking the bov only affects cars with the closed loop switched ON
yes? no?
congrats btw
cute has kinda become part of a bromance dictionary here in the north.. dont know whats going on in the east..
Why did you go Auto?
because im lazy
Any chance you got a CAD drawing of them? Might pass them onto the toolmakers at work to make up a set :)
I got my rings from speedy wheels
http://www.speedywheels.com.au/
Sent them an email telling them the ID and OD required and it cost me like $20 incl postage for all 4
i had some basic drawings of them. but ur better off doing them urself.
mine were done to my coils ID, the urethane bushes i had (superpro) and the bilstein shaft OD. the design is pretty basic.
from here i just drilled holes, counter-sunk the holes, then fit some bolts up through there. and yes the bushes are in the wrong way.
i also created some spacers to space down the bump stop to make sure the bump stop was what was bottoming out, not coil bind. this is done by taking basic measurements and getting the scrag figures for your coil (hyperco and eibach both have these in their catalog i believe)
Very nice.
What was your reason for the hats? Looks to me like you can achieve a lower setup without dropping down the circlip? This would mean more suspension travel without hitting the bump stops?
lol, it's easy man... just get 15mm bolt on spacers, and run smaller tyres.... get generic ones that have hub rings on them and then get some adapter that close the gap between the ring on the spacers and the oversized hole in the professors :wub:
run camber on the front and/or smaller tyres
i have 8" rims on my ksev and i run 195/50/15's
At least you make sense when you explain it :) Thanks man!
Now I just need to chew through my fresh tyres before I can buy smaller ones haha.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
