you're not accelerating if the clutch is in
Fair point :) I accelerate/brake simultaneously in other circumstances though.
Especially in an auto lol. My ZX. Accelerator + brake = lots of smoke :cool:
you heel toe an MR2? when? why?
I have to double-clutch to shift from 4th to 3rd because my gearbox is f**ked. Plus I think it's a good exercise anyway because it reduces wear on your syncros.
Edited by jezza boii
nor are you accelerating if you are braking :) how can you be going faster and slowing down AT THE SAME TIME?
I think Newton would have something to say about that..
The engine could be accelerating though :cool: Just not the car itself.
but you can accelerate while applying the brakes
lol what idiot told you that? you know that doesn't apply to modern (post 1990's) gearboxes right? they engage syncros as soon as you push the clutch in. I put it to you that you're fucking up your syncro's MORE by jumping on the accelerator like a tard and not matching revs to gears exactly (ie not needing to use syncros) while using your clutch still while you "heel-toe".
Also, syncro gears cost less than drive gears to replace. Unless you're driving an auto, in which case heel toeing is 100% retarded.
Widebody and still got poke. Damn.. Wonder what the specs on those wheels are.
I know exactly what spec they are. They're "omg look at this sweet shit on yahoo auctions, cheap too, I'll buy em and find out if they'll fit later" spec.
actually just looking at that pic, he may be running hard as fuck suspension so his tyres don't scrape and slight poke purposely. points to him if he is.
actually just looking at that pic, he may be running hard as f**k suspension so his tyres don't scrape and slight poke purposely. points to him if he is.
Has anyone really been far even as decided to use even go want to do look more like?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
