lol unless its a friday forget it i work every day lols.
needa swap back to my stock front guards better fitment but doin it after winton
You just want full bad as poke for your wheels yeah...
Haha!
So much easier to work on an EVO engine then a RB cuz there is so much room.
+ Your oil filter is easier to get to.
But having said that, if you know what your doing, you can get around it in the RB.
both engines have there advantages/disadvantages
although service on the evo piece of piss compared to the 32 even with the hicas pump removed
oil filter is a max 2min job, its arms reach underneath the car
Say whaa, nuh this one is in werribee
And says your choice or a Lancer Evolution 7 or a Subaru WRX
mmmm is it like rallyschool.com.au? or something
there was a guy advertising on evo forums for it once
yeh basically just dropping the lower seat lower (in my case winding it down), would have got me lower, but i would have ridden on the bump stops and given me no travel, this way ive done it has lowered the car, but has actually given me back my stroke, and complete control over it simply by adding in spacers to drop the bump stop to a point where it is bottoming out.
i actually dropped my car a while ago and after a certain point, winding down my coilovers didnt actually lower the car anymore, because the car was sitting on bump stops, not the coils lol. wasnt THAT low either.
haha nothing wrong riding on bump-stops :)
Will look into making some up! cheers for the help.
Went to watch my friend do the rally drive. He did a half day course and drove wrx's and evo's.
The trick to rallying is that you steer into the corner and accelerate as opposed to counter steering in drifting. So you pull the front of the car through the corner and the rear slides out. They'll explain it at the beginning.
So you gonna ban'em like what you did with Virgin Boy for the shit talk you cannot stand..?
funny thing is i wasnt shit talking lmao
what does the E infront of HNR mean on the build plate. awd?
the first E stands for the emissions standard it complied to. All the early ones met that emissions standards (till 91 I think) got an E.
the rest:
http://www.skylinesaustralia.com/forums/R3...tio-t38809.html
lol I think you'll find that's the difference in steering an AWD vs steering a RWD into a corner.
the rest:
yeah i know hence why i stated it. Not everyone realises the obvious esp when never driven an awd car before.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
