And heres another for you boys - a little old but still good.
Check out the dish on the light green S13, and how many sets of rims he has
http://vimeo.com/10050812
And just because we all wish this car was ours:
lol we;; he forgot to charge me for the fuel pump so im cool with that
bahaha... fail
that being said, i need to find myself another shop to take the car to. i wish trent still did mechanical stuff
:D
Contact Femno. I can SMS u his number if u want (if I still got ur number). Him or his dad do the work. Honest. Do good work and don't charge an arm and a leg.
think i might get matty to put in my oil cooler
What am I the SAU pirate? :D
Fark I should just bring my PC on next apple peel.
you're the one who admitted to having 11ty terrabytes of porn and no social skills.
I really want a 370.. such gorgeous lines. I keep seeing P platers in my area driving them. Damn rich kents..
370's aren't that exy, compared to say an M3. It's probably the only Fairlady other than a s30 fastback that I'd happily pay silly amounts for.
you only need to hard wire it running walbros that are flow rated at 15v
in the skyline it will get around 12v from the standard setup which is fine for a bosch pump or stock pump
you will gain zero by doing a hard wire. i woudlnt do it (if i was ray), just takes time which will end up costing you more for zero gain
if you put a wallbro in there and were peaking 240rwkw then yes hardwire if you insisted on wallbro, but otherwise get a real pump - ie save cost and safety
:D s30's....
i saw a red 370. was dumped on its arse on what looked like black BBS LMs
was in st albans if it helps lol
errr.... why?
i need to heel toe because i run a HHHDB clutch that bites like a bitch unless the revs are matched
that was a joke.
i drove a mate's (stock) 350z last night... once you go HHHDB, you never go back!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
