mate in india we get animals and people walking in the middle of the main road...no footpaths there....everyone shares the road and the fastest one traveling is the one on their foot...
LOL thats bad!
the most we get are the nomad sheep grazers who seemingly pop up out of no where and walk their sheep on the city outskirts.
big WTF driving along and seeing 100 sheep on the side of the road
We will leave wastelands if you leave our country.. Fair deal? Yea? Kgogogog
Do you want me to get Barbs in here to convince you that your Serbian/Bosnian/Yugo/whatever you are is descended from turkey therefore half black?
MAKE ME :(
Do you want me to get Barbs in here to convince you that your Serbian/Bosnian/Yugo/whatever you are is descended from the sphincter of the universe therefore half black?
^^^ LOLLLLL
Ah shit that guy!
He would to!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
