re-fixed. Tamils are dodgy as f**k. Just sayin.
dont tell me you are one of the singhalese people who hate tamils...why? i know both kinds of lankans and they both are nice people...other than the language they speak nothing is much different between them...or am i just naive that i dont see it....
lol he's tamil same as me, but we know how dodgy tamils are. actually so are singhalese peeps. lankans in general are shifty. they're quite "entrepreneurial".
as far as I'm concerned, unless you're aboriginal you're a migrant. and all humans are shifty kents.
Take that a little further and if u aren't living in Africa Where the whole thing started and were born there, youare a migrant.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
