re-fixed. Tamils are dodgy as f**k. Just sayin.
dont tell me you are one of the singhalese people who hate tamils...why? i know both kinds of lankans and they both are nice people...other than the language they speak nothing is much different between them...or am i just naive that i dont see it....
lol he's tamil same as me, but we know how dodgy tamils are. actually so are singhalese peeps. lankans in general are shifty. they're quite "entrepreneurial".
as far as I'm concerned, unless you're aboriginal you're a migrant. and all humans are shifty kents.
Take that a little further and if u aren't living in Africa Where the whole thing started and were born there, youare a migrant.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
