Was that aimed at me grant? Of course you can have a ride... Buller/deca are both coming up
can i become friends and get in on this? you can have a ride in my gtr :P
if i could have any car in my garage id have an Aston martin, i love those cars sooooo much :D
Hamish, yesssssssssss
Not going to Buller but going to deca if I can get a spot.
f**kin LOL!!!
This was talked about a while back in the feedback section
Who did it, and has you know who seen it?
:P
the sphincter of the universe
ahahahahah
barbs got owned
ahahahahah
barbs got owned
This dude was responsible for 'the sphincter of the universe'?
yeah, he would rant on about how islam is gona take over and how the sphincter of the universe is the new america etc etc
then posts about 60000 pics of the sphincter of the universe and explains how its eurasian, not asian or arab
Ah ok, so he was responsible for my confusion when I looked at my post when it show the sphincter of the universe instead of t u r k e y
Is he being punished for it or?
copped a couple of bans and various thread name alterations haha
So... Their aus/nz website excluded where's the best place I can go to get my hands on some matte bronze work emotion cr kais? And what offset would people recommend for ze GTR?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
