Well if you do decide to get the bbs's i reckon you should get the silver ones with the red BBS logo.
There is a picture of one in the vic post your ride thread i think. Looks the sh!t.
EDIT: i just looked, the gtr was silver my bad
Edited by El_Mutto
That mean I'd have to buy new - $$$$
I've got other bits I want to buy for my R.
It was only a week ago that I hate my R and somehow I love it again, geez...
I would of given up the GTST for the GTR as well. I'm not a very patient person.
I think why white is so common is because it is the official racing color of japan so anyone that would of bought a GTR would have been like I want a white one.
Its cos white were the last run of R32 GTR's. R33 GTR racing colours were blue, black and red. It's also the paint that didn't cost extra due to metallics or pearls :D
whats up with kids on scooters these days, when i was there age if you were caught on a scooter you would get bashed now all these little fags are everywhere, i hate them just as much as rollerblades, luckily its still the same with rollerblader's as it was when i was younger.
nick's R... is fkn rad!
+1
Not sure if I should 'superleggera' my bank account for a set cos a mate just tried to tell me Nismo LM GT4 would look good on mine...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
