guys i am due for a new phone....whats good to get? I really want to avoid iphone but if its really the best in the market ill shall...what other options do i have? any one got the new samsung galaxy? any comments on it? cheers...
Finally got my car checked out by a proper suspension place. Turns out my car is fine :) A wheel alignment will fix my positive camber.
The strut was what was bent. When I upgraded to coilovers it solved the problem.
Still not sure why 3 mechanics gave me different diagnosis's. First one said bent tie rod. Then one said lower control arm. Then 2 people said bent chassis :) Won't be trusting those kents again.
ask kriss its khoudars (spelling?) little brothers car was at winton on sunday think its runnin an rb25 from memory he was telling me but i like forget.
khoudar's 6.0? that thing is nuts!
anyone got an idea on swaybar prices? how effective are they?
cheap and massively good
because you touch yourself at night
as a previous iphone user, i can recomend the htc desire, its a good phone, or wait till the htc desire hd comes out, galaxy looks just like an iphone imo, and the case is tacky and plasticy
Still not sure why 3 mechanics gave me different diagnosis's. First one said bent tie rod. Then one said lower control arm. Then 2 people said bent chassis :P Won't be trusting those kents again.
so you're choosing to believe a mechanic who's gonna get money off you to work on your suspension and possibly sell you suspension parts to "fix" your problem... over a dude who actually crashed the car bad enough to get rid of it, and stands to gain nothing from telling you the truth.
I see.
God you're a dead set retard, you shouldn't be legally or medically be deemed fit to handle any of your own finances.
Either way if your mechanic can fix the misalignment with suspension then get it done. If I were you I'd take a string and start measuring points on the chassis diagonally and see if mirror diagonals are the same length (that's how you check for a bent chassis) instead of relying on people who stand to take you for a ride cos they've realised you're as gullible as fuck.
yes, they are. ever met someone vietnamese called khoudar?
no, no i haven't
the name khoder stems from my dads place of origin in Syria/ my mums area in leboland
interesting there are other arabs out there with what sounds like decent taste.
makes me all fuzzy inside :P
on another note, muck up day after-piss up. fkn drank half a slab. no hang over. LEGEND!
Shan, I went to Track Right and got it checked out this morning. They measured point to point from every part of the chassis and suspension. They weren't selling me anything. They checked it for free. They didn't make a cent off me. Just genuinely good guys. My workmate knows them.
So yeah, I trust their opinion over a guy who hit a gutter, tried to fix it himself, replaced everything except the strut and then thought "oh it must be a best chassis coz changing control arms and shit didn't work".
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
