considering the showie nature of his car doubt he going to pop rivet into his rear bar
then he's doin the right thing by not running a decat.
if you're gonna do it, go double the fist and do it properly. the only thing that a cf heat shield will retard is your bank balance.
Haha aliminium sheeting to protect bar... But your putting holes in it :D defeats the purpose
would rather have a few small holes than a massive burn
my car shoots massive flames.. it IS a 989fwkw monster after all :(
Cataylic converters is for homosexuals.
Real man runs cat-less...
I just let the black soot build up on bumper and tell people 'it adds character'
My car shoots flames all the time and my bar doesn't get burnt. Just all the carbon build up makes the bar black
If it doesn't burn your bar.. just polish it more often? The shields look ghey.
I'm tossing up whether or not to punch mine out
+1 to this. My paint is fine :)
it is gay...thats why its not in my list of phone i can consider to get for myself soon..
what did u end up choosing?
tbh, i would go into a store and test them both, jbhifi has the htc desire to test
are you gonna buy outright? you going with telstra?
