Jameh, I was gonna call u this weekend cept it rained all weekend :) no good for cars
Hah!
Yeah was shit weather...
There is an Apple Peal meet coming this Saturday, should catch up then...
You get the Corona going yet?
hey Basti whats the deal with this greddy e-manage you selling is the harness same for 34s or is it 33 specific?
no idea man. i was told it was a r33 harness and thats it. i was gonna put it on my car but have decided to go nistune. no idea what map is on it etc
Hah!
Yeah man driving the corona mobile too and from work now, the gtrs tucked away in the garage now :D under covers.
Hah!
Start saving the money, the Corona will save you so much in petrol and you can put away a fair bit of cash towards the GTR.
Hah!
Yeah well the 1st thing that needs doing is a bush kit, I do the back half of the car to start with and then the front later down the track, then new brakes and tyres. Then the car will be suitable to do some real driving as opposed to just grandma'in about
True!
In good time it will be all good again.
What brakes you thinking of getting?
Reason why i got a 33 gtr, i mean id love a 34gtr but another 20k for a LCD screen? lolwat?, sit in a r32 GTR and interior is aids or your girlfriend will adjust the air vent and it will fall off LOL. Front of 34 GTR = sex, rear of 33 GTR = win, if i had teh cash would make mine into a 33.4 or what ever theyre called, can always sell my xenons to help fund the conversion :D
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
