Hamish. I want a c's short shifter. But they discontinued. Are they a part the requires a good brand or would an eBay special do? If u know where I can get a c's one that would be awesome
eBay spe will not do... It's something that you deinately need the brand name on.
I can try to locate one, but they aren't cheap. Worth every penny tho if you wanna run a taller shifter.
Also well played on the troll... I saw what you did and I tried to troll your troll but you managed to resist temptation.
:golfclapemoticon:
My cheap 32 cost me 1500 with 4 months rego and a blown headgasket.
Bargain imo, there's a idiot asking 3.8k for a shell with rhs side wiped out...
So found rb25 and box for 2800, add 1000-ish for brakes and other bits, add 1000 for engineers cert.....
I don't know what I want to do...
haha true, but nothing is ever that simple in r32's :D
Where'd you find such a cheap r32?
Firesport, when I looked at it the symptoms were telling that turbo is blown, when I bought it home the symptoms are pointing at blown headgasket along with cream on oil cap...
Fun times ahead...
Already considering ebay it and see how I go...
Fun times ahead...
remember. pods and skirts. mineee!!!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
