haha :D
nah cant even drop a u-turn on a 2 lane road in the evo...... its all 3-point turns now :P
yeah thats how most sickcunts write them off cause they dont know how the attesa reacts etc
Ric the SS will be fine man, dont need to go heavy spring rates for street
they would be better than the bc/br
bahahaha i can do u turns and i got awd. blow me bitch!
and yeah. took the car out with my uncle one night. wanted to see how it feels when the awd kicks in in a car park
tbh, i was shitting myself. every inch of me wanted to counter steer
my GTS4 has longer lower control arms and wider steering rack knuckles for extra angle. eliminates the ghey AWD turning circle dilema at low speed as a bonus. failing that, power in, reef handbrake, instant 180.
shan DO NOT REMOVE THE VW badge!
i just noticed its become a w
WEST SIDE!!!
your gonna look so gangsta if its got a W :D
fuck off.
hell will freeze over before I take styling tips from your arab ass.
My sisters golf looks better! Whats going on with all these parts you have been buying? collecting dust?
waiting for christmas break to have some free time to work on the car. for now it's just being used as a beater daily.
Your golf stud pattern 5x120?
nien, that's porsche fitment.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
