well he certainly had a bad taste....lol....well it was good for you wasnt it.. :)
Yeah, worked out well for me. He can have his Failside sideskirts while I enjoy the nice Sard/Toms combo he sold me :)
so you took the dregs off a dude that has shitty taste? what's that say about your taste in aesthetics?
These are the sideskirts that I got...
Nothing like the failside ones. I'd say my taste in aesthetics is quite good compared to his :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
