Newfagz don't know bout demon camber
In other news my wheels are getting made this week and will be here by end of Jan
So true!
What wheels you getting again?
Car was at Centerline today, drives nice and straight now :P
Funny thing is im running -4.5 degrees camber front and -2.5 rears. Fronts would be upper arms and lowness combined haha
Pics yeah :blink:
What kind of camber settings would be best for a street car that enjoys a few twisties every now and again?
-1.5 degrees all around?
I don't know much about that kinda stuff so i'm off to do some more research.
Lol demon camber looks like ass. Looks like the car is cocking it's wheel to take a piss like a dog
this... is true
matte black XD9 17x9.5+17 f and 18x10+18 r w 235/45/17 AD08's f and 235/40/18 KU36 rear
cusco upper arms will probably mean 20mm spacer up front so et will be 17x9.5-3
More tyre on the road the better. Eg billys 4.5 deg camber on front would make te car understeer like a bitch when pushed on corners
err... the point of cambering the fronts is to GET tyre on the road while turning, and hence stop understeer
see pic attached:
race cars run camber for a reason
when you turn your wheels they dont turn evenly as such, they tend to roll over and reduce the contact path, by adding camber, this roll over effect is negated and contact is again made with the road. see above how on the c-west s2k the wheel is turned and the tyre is nearly flat.
4.5 deg camber will be much much better in the twisies/track than stock setup, but will wear the tyres down unevenly for DD purposes
i'm gonna be aiming for -3 deg when i get the new rims
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
