Nankangs..?
Any good, I thought they were some pov pack tyres like NEXEN's, which I have used before...
nah man they are fkn shit, get what ya pay for
also lol@ that pic. Nice car and mods, but seriously, on an angle and turned in? that's like parking your car on grass and claiming it's low.
haha truth. hate the poser grass parking bullshit.
I've never owned an R32 for more than 3 years. I keep cycling through them, I sell em as soon as they're gonna lose value and upgrading etc.
I got all attached and shit to my GTS4, which is where I went wrong, otherwise I'd have gotten rid of it 2 years ago.
longest I've technically owned any car is the ceffy. Bought it for my dad in 2005?
Anyone who's owned any skyline, that's not in mint collectible condition or is rare as rockinghorse shit, for longer than 5 years, is a fool.
Wheels and calipers are awesome!
How come some times the caliper is mounted at the rear of the rotor and some cars have it in front of the rotor..?
Has it got anything to do with cooling the brake pads when mounted at the rear of the rotor ^^ as pictured above on the BMW M3... Or is it just for looks?
They are alright for now, pretty grippy. Not that I care, they are rears and dont last long anyway ;)
Slide ways action out in the Wild West-side of Melbs :/
Yeah, I thought so haha!
picked a colour that was close enough to the basecoat, but still shiny enough to look good on the golf...
Mazda Stormy Blue
totally diggin Mazda's Aurora Blue as well, but unfortunately, is a different basecoat to the current paint, which means I'll have to spend more time painting it.
This would be sweeeeet, but I doubt I'll find a sample to mix the paint off:
Having to make a claim because vicroads are a pack of ass bandits sucks.
The fact that requires to make an at fault claim sucks more.
At least something is being done...amazing how helpful just car is when excesses come into it.
Moral of story: I'm flat broke but just car are picking up the R with a tow truck in a few days to be assessed.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
