russia's not all covered in snow and def not all through the year you luddite.
do not correct me while im trying to make a point. kthx
Bade hey rimon. Fkn Arabs. Qatar sucks. Seriously, it's like a wannabe Saudi. And their Arabic is bastardized to the point where I can't understand them.
Btw, girl didn't really die. I just yelled at her for doing something unfavorable.
yea we shoulda got 2022 man sif that cartoon kangaroo thing wasnt impressive enough... bet that julia gillard f**ked it up for us
hey muzNick whats the 6.5 TM like? is there much difference mechanically to the 7s or? drove next to a blue 1 today they look tuff as, looks nothin like normal lancer
TME are pretty good, mechanically they dont have the active rear diff like the 7/8/9 but that doesnt really matter
light than the 7s and heaps faster..... different seats and steering wheel than the evo 6, no radio, titanium blades on turbine.... thats all i can think of atm
no radio? f**k that lol
otherwise mmm interesting
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
