cbf wasting my time with that shit. not like I'm selling anything on here anyways.
Haha!
True that.
Sold the sedan to a mate, helping him add his 'collection'
Between him and his missus, they have 3x R32 Sedans...
Damn!
They must love the 4 doors.
Whats reason for collecting them?
Is 1 a daily / track car / Missus car?
I'm Sick to death of hearing about this "Drink Dirving Blitz" that is supposed to be coming to Melbourne...Farken.
Has anyone a Significantly increased amount of police presence on the roads on Fri/Saturday nights?
yeh a little bit, more booze buses and like cop cars setting up make shift booze bus stations without the bus
Really, I've seen the Regulars doing the Rounds; Ie the Westgate, Abbotsford (Behind the CUB Breweries) on the Monash, but that has been about it.
I thought I was going to get pulled over every 5 minutes...
Carbon on the rear is the way to go. On the bootlid and on the rear bar lol
if i go carbon boot im pissing off my rear wing otherwise itll loook weird, carbon blade yellow spoiler and carbon boot
but i prefer my spoiler so it stays :P
So jci effectively lost my car for 12 hrs... Had to spend 20 mins on phone to assessment centre to find it.
Dear god I can't wait until I'm 25... Drop this useless bloody company like a bad habit...
haha RACV insure the evo even though its an import and im only 23 :)
$800 full comp with agreed value :D
$800 for 26k-ish market value?
Awesome price...
I had one and switched to iPhone4...
you srz? i did the oposite...used my mates iphone4 for a bit...hated it...then when i got my galaxy, i am in love with it.. :)
couple of my mates did the same...went from apple to galaxy...
in a pulsar? rkn your safe :laugh:
  • Like 3
all my mates who bought HTC Desires and Galaxy S's when they came out over the iPhone 4 are all now complaining that they freeze up, are slow, don't have good apps etc. Apparently everytime you install an app they leave rubbish processes behind that slowly slow the phone down, and even task managers don't help cos they're system level daemons. Then there's the fact that they have to sit on 2.1 till Vodafone push out an update, and the ones on Optus are on 2.2 but don't have an update for the HTC Desire's, only Samsung Galaxy S.
The only ones not complaining are the ones who rooted their phones and installed Vanilla or custom OS's.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
