VSPECT - PM location of this cruise and which club it is ;) oh and when haha
Vic imports cruise Kriss is goin it's tomorrow meet about 11
Oiiii ask Dave Neil doesn't do exhaust shit plus they never reply lol
I'm at work tomorrow, oh well! Spewing!!
Neil deals with customers lol don't be a pansy and msg him.
Done....i am calln in sick to work to make it to this... :P ....
Jamie, pics may be up tonight,
Harsh, I'll have fun driving something with real power!
can t wait to see the pics up....ur old car had real power...n if this new is faster...DAMB!!!! cant wait to see it... Congrats!! :)
It is currently 30rwkw less than old R, but I'll sort that out. And thanks.
is it a R too or some other car?
Cmon Vic imports cruize, hope the weather holds off
tell me about it...it better not rain...otherwise ill be forced for some awd driftn...lol....
I've got 24th - 2nd off. Let's have an SAU meet in my driveway so I can attend with my broken car.
Actually we kinda did that once lol. Brought 30 cars down my tiny street at like 11pm haha. Neighbors didn't appreciate that one :P
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
