same here...there is a massive cruise tommorrow that ill b going to though...if you want you can join...pm me if interested...just dont want to post it on here coz the mod of that club is on here and does want its activities talked about on here.. :) ... expecting 150+ cars...
he drives it around...but when you coming out and showing me ur beast.... :P
:D didnt plan to but will if you coming...just to hear your car once again... :P
Won't be going anywhere in the rain.
Who's got time off work between Christmas and New Years? Should have a Vic Wastelands meet lol
going to south korea to snowboard from 26th to the 2nd.
some of us werent cut out for ownership of r32's. Time to change your DP Shan :P
my DP hasn't worked for a while now cos I cbf'd renewing happysliders.com domain name :P And yeah 10 years of owning various R32's is enough for anyone.
meeeee 3 weeks w00t.
wanna meet lavo maccas? hektik.
and ask dave ffs you'll be there allllllllllllll day given him knuckle shuffles anyway
Thanks man :)
Nah not tonight. I won't be actually "cruising" until I get my car fixed. I can't even get it into 3rd gear half the time. It's so rooted. It's a real shame I didn't get it finished for summer :(
know the feeling! Mines been sidelined 5 months now n won't be back till at least late January. Formerly broken car cruise next yr? :P
got 25th off, but busy. Also at this stage the 27th and 28th, and real new years day. I also have 2 jobs lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
