It's getting a boost controller fitted at least, depending if I can afford more, we'll see. But upping the boost to 14 pound will see me clear 210 I'd hope :P still has tiny compliance cat constricting the middle of my 3" exhaust. Must fix that...
Jamie, pics may be up tonight,
Harsh, I'll have fun driving something with real power!
About 6.45pm @ Princes Highway before Wellington Rd, I spotted CR33M?
I was in Black 32 GTR heading opposite direction, unsure if you saw me.
Ah, didn't see the driver, busy enjoying the R.
Pics! :D
15.5k for 270rwkw 32 V Spec.with RWC.
Mods are the following;
R34 N1 turbos + dump pipe with HKS actuators.
Power FC.
Nismo Front pipe,
3" Hi flow cat.
3" Cat delete pipe
Apexi N1 cat back.
Apexi RSM.
Apexi pod filters.
Pair of Recaro SR3 seats.
Tein Coilovers.
Whteline Swaybar (F + R)
Adjustable cam gears.
HKS EBC (EVC4 i think).
Apexi Pen turbo timer.
Nismo Gearknob.
17x9 +19 SSR Evolution Wheels.
Have standard exhaust, suspension, airbox.
sounds alright, decent price as long as it doesn't blow up in a week....
Something luring about a 32 GTR...Hard to go against a 33 for around the same price, but something about a 32..
will have to make a decision when the time comes
Rb26 can blow up in 5 mins or never, may as well enjoy it.
I know what you mean on deciding between 32 and 33, last year I had trouble finding reasonable condition 32 at reasonable money, In the end I bought 33 off ex club member for awesome price (for a 33).
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
