Hamish is using Nismo 555cc from memory, maxed at 92% injector duty.
Go bigger, Nismo also have 740cc, won't max it out for what turbo you want to run (you're wanting GT3076R correct?)
Interesting....
I might get some 800cc's... Im thinking about getting the gtx3076 but I wanna run external gate, so I would also need a new manifold which is more costs.
So for the time being im thinking about maxing out the standard turbo, can someone tell me the max ill get out of it?
Maybe 200-220rwkw from stock turbo before the rear wheel doesn't cooperate.
and i wouldnt boost it past 14psi. after that the ceramic wheel tends to get messy as above comment mentioned.
Yep, anything substantial over 200 is pretty much the dyno. I wouldn't be going past 12psi either as already stated.
Even following that rule, it's still hit and miss. People like Paul have been running 12psi on the stocker for years, no worries, I've had mates turn the boost up to 12psi, put it on the dyno to tune it and go bang on the first run.
Mine lasted a while, probably over a year from memory, then it let go at DECA and unfortunately took the engine with it, so it's a pretty big gamble :)
My tuner turned the boost on my stock turbo up to 14.5 psi. I've size turned it down to 12 psi. Wont be going back there again.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
