Yup.
Not sure why I'm a stupid twat for buying it.
my garage always has space for another car, i'll get rid of it for you, cash my way?
explain
There's a thread somewhere, about aircon blowing out hot air, something about a plug not contacting properly, so the paper is to provide a tighter fit.
no perma fix though.
don't think your car's been regassed since it was degassed to get into the country Virgin Boy. hold the temperature down button after it goes does to 18 to force it to pump cold air (bypasses sensors) if it's still warm then you need a regas.
^^^ Set it on fire, best thing to do on R32.
Kris, I'll PM you or PM Josh if he's on this forum when I'm available to be scared.
Haha kk mate. Let's put it this way. No cars on the hwy could beat us. The car is bloody ridiculous. Joshs forum name is CR34M
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
