Was a decent smash on Punt Rd/High St last night. Was lying in bed and heard a massive bang, so I got up, jumped in my car and went to investigate. Looked like a cab ran through a red pinning a Daewoo against the traffic light pole. I heard the accident from nearly 2 blocks away.
lulz, page 404 of thread
Short story, it's R32 GT-R.
Long story, too many things that decide to work whenever it likes.
how is it that I've owned two 32 GTR's and neither (including one that was makin 380awkw on a big single) never had as many issues as you're making out to have? are you just being a princess and havin a whinge or you havin legit problems? If you are then STFU, sell it and buy something that's not gonna give you issues. I hear Corollas are teh reliable.
also, angry birds on PC and on Mac App store. FFFUUUU... there is no escape!
  • Like 1
I have both legit problems and me being a f**king girl.
I have access to a Corolla with new motor cos my dad is lazy f**ker for not maintaining it properly and destroyed old motor (it is 2004 model BTW).
haha did you go for a drive in al's?
nigel was the old co-owner of ice performance from about 5 years, he had a 32R with a big external setup and the firewall was on fire, from the dump pipe heat
nah... just know what i want and al's dyno seems to be the most appropriate for me:
i want max response, snappy on/off throttle, ~300 rwkw, lss stress on the motor and power everywhere, through to 7k
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
