my honest advice?
buy a NORMAL NON TURBO AUTO bucket of bozz first car
drive it till the doors fall off and you get off your p's
then you can drive, are allowed to drive normal cars and a bit smarter with looking after cars (i didnt look after my first car)
then you could probably go staright to a GTR 33 by that time and youll have a real car first off
imho dont bother with a nice turbo or engine swapping etc - takes time, $$$ and effort etc
doesnt have to be a bucket of bozz
but forget about all this engine swaps etc
my first car was an auto vl n/a bozz
it was in ok condition ,everything worked, and it drove fine
i never looked after it, never serviced, never did anything
very reliable otherwise, it had more oil in the engine bay when i sold it, then it did in the engine
then i sold it for 2k and got my r33 gtst
kids these days want the best, latest, fastest, bestest car EVER on their P's
and it has to turbocharged, it has to be blah blah
just buy a normal car
you dont have to keep up with the other knobs "cos they do"
Do what I did, drive a N/A 33 manual coupe for 3 years, get off Ps sell it and buy a GTR (couldn't get a 34GTR though still 40-50k for the base ones -_-) so got the next best thing a 98 33 R!
I was also SO close to buying a Evo 7, man I love those things but I wanted to own a turbo skyline before I got over them.
But CA's aren't the world's most reliable engine. N/A SR20 is a much better choice.
wut? SR20 engines come with factory busted lifters. CA's are bulletproof in the hands of a tool, esp with no forced induction.
Do it, CA18DE then weight loss the crap out of the car and give it good suspension. Look into changing the cams out of a CA20, $20 mod, makes it rev better. It'll be a great car to learn in.
Seems like the meme to me. Umad vicpol?
makes me wanna go out and get UJELLY for the 240z and UMIRIN for the golf.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
