which would be a great idea if we pricematched with the Internet. Cept we don't.
Price matching applies to local business only. And part must be identical.
See but if they have a ebay store, you can find out if they have an actual store, in which most cases they do eg. access auto, cj motors etc...
So we do price match for that reason.... ;)
haha..well... Where I work at autobarns we don't match the Internet. No if's ands or buts. Ask us to match the actual store might be different story, that's never come up... But the moment u say eBay it's game over :)
lol and yes jez... It is pretty good :D
I could probably get it cheaper anyway. Autobarn staff discount ftw :P My mate always gets me cheap shit.
Yea it showed that you went to autobarn frequently on your old cars with the neons and LEDs pouring out of it lol
that looks okay shan, but if i wanted euro i would go 5 series bmw
fark fark fark fark
theres a legit 180sx type s (na type x)
f**king want! need to sell car. NOW
offer the guy a swap plus cash. hopefully he's gullible enough to take your car. just sell him on the pipedream that it's only a manual gearbox and an RB26 away from being a GTR sedan.
who in their right mind shops at autoyarn anyways?
From the exedy warehouse lol. Just speak to the guy that sprayed your car ;)
The guy who sprayed my car? Or the guy who owns the shop that my car was sprayed at? :P Two different people.
f**k your as bad as an arab lol
Okay, is 2k ontop reasonable?
At work on break...
The GTR is getting new fuel pump later today as stock is dying.
Now I gotta find something to amuse myself between 2am to 9am and not sure if I'd feel sleepy.
May I suggest masturbation?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
