Power steering is gay. If I had it, you could take it. But I don't :)
MR2 powersteering is used on track car builds cos it's full electric. plus it's bang for buck better than a lot of aftermarket units. pretty easy to control on and off etc via in switch cabin. Turn it off to conserve power, turn it on for quick maneuvering (ie, drifting/racing).
road going MR2's couldn't care less, but when you remove the power steering pump and all that shit off an RB/SR/1J/2J there's a substantial improvement in engine power. Then bolt on electrical MR2 pump and instant partytime. Weight loss + response is awesome. lotta Mazda/VW/Datsun/Nissan/Toyota guys do the mod.
Reason you don't have powersteering in your car is cos it was a very expensive option, and a lotta peasant spec owners didn't choose it when they ordered the MR2. The reason it's electric is cos your engine's in the back, and your driving wheels are in the front. It's cheap for us from factory cos everything's in the front. Make sense?
lol I had 3 very long cracks through my dash after parking it in the heat one summer.. bitch to swap over :\ I recommend not pushing your luck with that..
those louvre things are cool but what the fu..gly colour...
justjap have aircon vents, not sure if they still have stock but for the time u spend looking for them and find nothing, might as well spend the $100odd and buy them brand new
R-Spec: just go for a drive, bound to find some right behind you within minutes
haha its been going strong for 5yrs. Bring it on 2011 summer!
Does a rear strut brace on an r33 make a noticeable difference? I was pleasantly surprised when I put the front brace on the car but I'm yet to put a rear on. Any opinions?
dunno, i know on r32 suspension they do shit fk all. (as expressed by sydneykid)
Yeah, i noticed an impressive difference with the front strut brace on. Just not sure about the rear one given i've seen some posts from SydneyKid which states they do absolutely nothing.
So you noticed a difference with the rear brace Grant? Can you give some details?
went to pick up a little dough mixer in my car today, at the lights, cop pulls up next to me
im thinking, oh f**k my life. (i had a paper from the boss so i was all good, just hoping they wont pull me over and defect me for the tee and the tt)
so.. i cant resist the temptation and look to my right to see if their looking, whattdya know, their looking.
crack a sheepish smile and get a nod back. that was it..
lawls. Loose the Tee and that rice turbosmart sticker in the engine bay.
Yeah, my old gtst came with rear brace not front for some reason, when I removed it it felt sloppy around corners, with that in place felt much better, then along came front brace. That was with standard suspension btw.
You think a letter from your boss supersedes the law?
You really are a douchebag
vicroads website says im automatically exempted if a letter is written by my boss bla bla with business hours, telephone numbers and shit when i drive the car for work
have to keep it on you at all times, and of course no ridiculous hours like 9-1am etc i got 7am-5pm thats when i go to and from work, after that its cruising like a hard kent in the territory lol
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
