went to pick up a little dough mixer in my car today, at the lights, cop pulls up next to me
im thinking, oh f**k my life. (i had a paper from the boss so i was all good, just hoping they wont pull me over and defect me for the tee and the tt)
so.. i cant resist the temptation and look to my right to see if their looking, whattdya know, their looking.
crack a sheepish smile and get a nod back. that was it..
CSH
does a note from your mummy count?
lol i wish
hamish- twas something like that..
todays looking like a shit day, both wisdom teeth moving on the bottom jaw, both gums swollen as f**k
yayyy
Power steering is gay? Lolwut. Just because toyota was too cheap to put it in your model lol
They put it in all the jap ones. They knew aussies were hard kents so they left it out til '94 :P I fkn love it. Get a much better feel for the road and MORE POWAHH. It's just like having a HD clutch. Gotta harden up and deal with it :)
girls love those dimples
and im flattered jizzy, you have a pic of me on your comp
the start of something beautiful? :wub:
lolz how did you get a pic of mohsen? facebook stalking?
Edited by Clutch
Everything else would fall apart though. Except the engine lol
:laugh:
Thats the plan really, gonna get the rona done then look at my funds for another week got rego and rent coming up tho that will be 1k together mmm but should be able to get the gtr happy again in the next month :D
Cool!
I read that post on Speedhunters too.... loved the Blitz and Top Secret GTRs. Some of the others were pox (Abflug :sick:)
Ah yeah, that wide body R35 GTR... WTF?!
:laugh:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
