what about driving back home from the shops on Sunday at 4pm and copping a full epa :(
/sux to be in Knox council.
Times pulled over;
- Driving to Kmart on Sunday evening = defect
- Driving to Status Tuning after work on Wednesday = defect
- Driving back home from shops on Sunday afternoon = defect
- Driving back home from shops on Sunday afternoon = epa
- Looking for carpark on chapel street for dinner on Thursday evening = license check and on you go :domokun:
Majority of my defects/epas have occurred on Sunday afternoons. I dont like Sundays :down:
i know this isnt the right answer and my car is the same
but....................
you are driving an illegaly modified car.......................
thats a skyline........................
thats loud....................
twas very frustrating, just when you think its getting smoother and you start moving more than 10km/h....bang! you drive into a fkn hole
beater car sounds like a good idea
true. price of cars drop but cost of repairs/parts/maintenance dont. could go manual and save the headaches but i want the sequential
well thats cos the parts are still new my wing mirror cost 2k for one 1200 for the plastic shit and 800 for the heated glass stuff... headlight was 3k.. *shrug* car companies dont make profit on cars any more (apparently) they make it on the parts
my r32 is quiet compared to the trumpet exhausts around here haha
I had a cop who said that he believes its loud but wasnt sure loud enough for a defect. Told me to get it checked out just in case in my own time. Never did
f**k it, f**k it to hell
im bringing the r32 to the cruise
at least i can enjoy it and be paid out for driving an auto taxi in person for maybe the last time
also, full throttle, it spits out flames sometimes.. wdf
Wait till tomorrow night when your balls fall off and you choose not to go again.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
