I'm just pissed off, have been all day!!! f**king shit f**k ahhhh happened last night leaving my gf's. Reversing out of the stupid altona meadows driveways. Tyre pulled it in nice, having no luck fixing it atm :( now it just looks ridiculous, I've made a mess of it!! Sigh
know exactly how you feel. only my tyre pushes the lip out while getting in our driveway and i have to push/roll it back in. then i go cursing everyone who's parked their car within 50m of our house for not giving me enough space to do a 11ty point turn to get the car in right without rubbing the guard :/
And there's me getting quotes for 265 fronts and 285 rears LOL yer for sure
wtf you want tyres like that for?
oh wait haunted hills ?
get ya primal mates to fix it for ya cant be beyond repair if it is i picked a rear bumper up last night off a guy in balwyn parting out a white 33 had front guards there i could see
So I can go faster around corners! Lol
It's pretty f**ked, see how I go tonight. It looks like ass but as long as it's not touching I don't care!!
That would be handy. Can't imagine what it would look like though.
In other news, going to check on my car on Friday. Too excited :) not done yet but close-ish!
Can't wait to ditch trains every morning!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
