Why baby blue stokers tho?
One day couple of years ago he was bored and decided to spray it with some spray can we had laying around and that's it
replace the wheels with some decent non ugly ones and it'd look good....
what's wrong with it mechanically?
Yeah, was umm and ahhing about getting work meister for it.
Currently there's a leak from somewhere and it need retune badly.
Body would need a respray but couple of friends suggested cut n polish but I don't think it'll work.
While you're here, may I ask how long did you have yours?
And have you done anything exciting to it?
I bought my GTR back in August 2005.
Changed new front disks and brake pads.
Rebuilt Rear Diff.
Rebuilt Turbos to steel internals.
New OEM Clutch put in cuz the HKS Twin Plate just about had it.
Aftermarket Front Pipes and a Highflow Cat put in... Also have a Cat Back oval shape muffler going on.
New OEM Slave Cylinder.
Did more rebuilding rather then modifying.
I can dump money in it for the "Go Fast Mods" but I know 1 thing leads to another as this car cost already, as it is.
It is lightly modded and good enough for my weekend drives :)
I say you should enjoy what you got there (your R32 GTR) as you know, the power bug has hit you and you will never be satisfied...
First it is 200+ kWs, then you want 300+ kWs and you will be chasing 400+ kWs... It never ends... Leaving a bigger hole in your wallet.
Lower your standard of your expectation for your car and you will enjoy it better.
Remember, you do have decent mods on it... Utilise it and enjoy it...
That's what I think anyway :D
scar non?
Landed at hamilton island at 12 then had to evac at 4pm :(
Ho hum :(
go to the shooting range and hire a golf buggy and try get air in it haha
Was only there for a day passing through to the barrier reef. How long you there for?
yeah we are still on holidays , just not on hamilton island. Yep 4 hours , landed at 1230 and got ferry off at 4pm. We had time to try and get flights out (no chance) and time for a quick walk around a few drinks and lunch
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
